Ana içeriğe geç
The Samsung L100 is a digital camera that was released in February 2008.
10 Soru Tümünü görüntüle
My camera wont stay on.
The camera comes on, the green light on the back flashes once. The lense starts to come out, then immediately retracts followed by 3 beeps.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
6 Yorum
I go with a stuck lens. It can cause errors the way you described yours. Check on here for more info
tarafından
I'd agree with oldturkey, it's a good link too
tarafından
Hi there
I'm sure you have problem with lens of camera . is not that eays to be fix by ur self if you don't have exprince on repair camera but you can try .
you have to know some time after fix it stil you have problem that is u can see line on you lcd screen . is mean you have change your lens .
I do repair cameras .
tarafından
Hi there
I think you had problem with lens Of your camera ./ maybe you dropprd your camera.
cyrus_7029@yahoo.com
tarafından
I seem to be having the same fault with my Samsung L100 camera. I fitted a replacement battery and still the same fault is present
tarafından
1 tane daha yorum göster
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
First, a easy fix, charge the battery overnight, put it in, power it up, if you yield the same result, replace the battery and see what happens
I will update this after we have more details on what happens and what you did to troubleshoot
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
I think the answer is in the question Read the second sentence carefully....
tarafından
Yorum Ekle
Yanıtını ekle
matt sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 1,717
