Ana içeriğe geç
Saturn Relay, Amerikalı otomobil üreticisi General Motors'un Saturn markasının ilk ve tek minivanıdır; Buick Terraza, Chevrolet Uplander ve Pontiac Montana SV6 kardeş modelleriyle birlikte üretilmiştir.
Cooler radiator leaking oil replace how
Transmission cooler radiator leaking oil replace it instructions
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hey, Elisa. Remove the plastic cover under the radiator to access the draincock. You’ll need to drain the coolant from the radiator and dispose of it properly. Disconnect the two transmission fluid lines that connect to the radiator/cooler assembly. Disconnect the upper and lower radiator hoses. You will most likely need to remove the radiator fan and the fan shroud to remove the radiator. Be sure to keep the radiator cap from the old radiator, as new radiators typically do not include a new cap. Remove and replace the radiator and refill with the proper coolant. Reconnect the transmission lines and be sure they don’t leak while the car is running. Check the transmission fluid levels and refill any lost fluid. Let me know if you have any questions about specific steps and good luck with your repair!
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
elisajackson sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 16
Her zaman: 718
