Ana içeriğe geç
Apple'ın 13 inç MacBook Air modelinin Nisan 2014 güncellemesi; yenilenmiş çift çekirdekli i5 ve i7 işlemciler ve biraz artırılmış pil kullanım süresi içeriyor.
Hall effect sensor - screen closed
Hi,
I have just been replacing my screen but the hall effect (sensor that detects the close of the screen to put in sleep mode) is not working anymore. I have found that this sensor is on the I/O board but I do not know where and how I can fix it. Thanks,
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
What part did you replace exactly, the screen assembly ? The hall sensor connects to the I/O board and it’s on the topcase, but it needs the magnet on the lid to be working properly. Unless the sensor was damaged somehow the only reasonable alternative explanation is that your replacement screen is missing the magnet. If you have a magnet around it will be quite easy to verify which of the two fits your case.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
If you replaced the display you might have dislodged the magnet held in the lid frame, or the hall sensor is bad
Resim
Using a rare earth magnet slide it across the uppercase where the sensor is located you should see the display turn on and off as you pass it across the sensor. Use a piece of tape to mark the location and now using a steel paperclip locate the magnet in the lid and marking its location the two marked locations should meet up. If not you either got the wrong lid assembly or the magnet is missing or got placed in the wrong hollow when you replaced the LCD panel.
Puan 1
Yorum Ekle
Yanıtını ekle
Pierre-Luc Vérité sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 19
Her zaman: 641
