Ana içeriğe geç
Repair guides and disassembly information for laptops manufactured by ASUS.
2523 Soru Tümünü görüntüle
Keyboarding is not working and external USB keyboard won't work
I have an Asus laptop model X540S, the keybaord stopped working and I am locked out because my laptop is password protected. I attached an external USB keyboard and that will not work. Any thoughts ?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum
Did you attach the external keyboard before turning on the laptop?
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
If you already tried all the laptop’s USB ports for the external keyboard, you may have to remove the computer’s keyboard and install a different one.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Try starting it up in “Safe mode” and see if it will load then. If yes, then there is something on the laptop(virus, malware, etc.)
1-Then try to restore it to an earlier situation using restore point option.
2- Or go to the Driver & Tools on the related ASUS web page :
www.asus.com-Laptops-X540SA-HelpDesk_Download
download all the related drivers again and save them in a stick memory. Try to install them in safe mode if it is possible.
But before that try to use the attached keyboard and boot in safe mode (following text).
I hope it helps:)
Boot in safe mode(Wondows 10)
A-Turn off the device. Attached the external USB keyboard again.
B-Click Windows-button → On/Off.
  1. Hold down the Shift key and click Restart.
  2. Click the option Troubleshoot and then Advanced options.
Afterwards go to “Advanced options” and click Start-up Settings.
Under “Start-up Settings” click Restart.
Several boot option are displayed.
Select an option by pressing one of the numbers or function keys F4, F5 or F6
Enable Safe Mode
In this mode, the operating system is started with the bare minimum of installed drivers and only the main Windows functions are used.
Puan 0
Yorum Ekle
Yanıtını ekle
CorgiGirl User sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 55
