Ana içeriğe geç
The RIDGID R2740 is a heavy-duty corded belt sander. The intended use of this device is meant for, but not limited to woodshops, at home and construction sites.
2 Soru Tümünü görüntüle
similar Craftsman 3x21 Belt Sander 315.117260 disassemble for repair
Upon disassembling the sander, I found that the left armature bearing failed, heated, and melted the plastic holding it in place. I can’t get the gear off of the armature in order to take the damaged parts off. I think it’s reverse threaded, but no way can I get it to budge. Help I would think a repair should be possible. Or, have Craftsman tools gotten so bad that this cannot be repaired?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Have you tried heating the part?
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Hi Kevin, No, I pretty much gave up and set aside the tool. I recently found the box that I put it in - maybe I’ll give it another go. BTW, would you be interested in buying this for parts? Chris
tarafından
Yorum Ekle
ereplacementparts shows parts available
https://www.ereplacementparts.com/ridgid...
Puan 0
Yorum Ekle
Yanıtını ekle
Chris Longwill sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 9
Her zaman: 262
