Ana içeriğe geç
Haziran 2016'da piyasaya sürüldü; Avrupa'da A3003, Çin ve Kuzey Amerika'da A3000 model numarasıyla tanımlanır (https://forums.oneplus.net/threads/oneplus-3-regions-model-numbers.452381/ adresine göre)
Digitizer does not work after screen replacement
I replaced screen and digitizer and it seems everything went fine. The phone turns on but the touch doesn't work, the back and all app button do work. I tried doing a factory reset but it stills doesn't work. What could be the problem?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi Neil,
I would suggest disconnecting and re-seating the display cable. Carefully check the connector for any debris—the pins on the connectors are tiny.
OnePlus 3 Ekran ve Sayısallaştırıcı Bloğu Değişimi
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Hello Arthur,
I tried disconnecting and re-seating the display cable as you suggested but still nothing. Could it be a motherboard problem or should I send back the display+digitalizer and try with another one?
tarafından
Hey Neil,
It could be a motherboard, though I'd think that the display may have a slightly higher chance of being the problem. Does the original screen work enough to be used as a test? Unfortunately with how the replacement is set up, it's not easy to swap displays.
tarafından
Yorum Ekle
Yanıtını ekle
Neil Considine sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 17
All Time: 540
