Ana içeriğe geç
ASUS Zenbook Flip S UX370UAK (eski) / UX370UAR (yeni) 2'si 1 arada dönüştürülebilir, kalem desteği, parmak izi okuyucu
What screw size is it?
I have Asus Zenbook ux430u and I want to replace some parts but I don’t know which screwdriver I should use.
Resim
Bu iyi bir soru mu?
Puan 2
1 Yorum
TORX T5. You'll find this in many kits.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
T5 or T6 for the Zenbooks - it depends on which one you have, so I would get both just in case. It isn’t a TR Security at least, so that isn’t an issue. More then likely it’s T5 because that’s historically what Asus uses in the Zenbook, but T5 and T6 are very similar looking to a point on devices like this, it’s best to have both. It uses Phillips #00 screws like nearly every other laptop in the PC sector internally.
I would also get the 64-bit driver kit just in case it’s something obscure even what information I have doesn’t apply. You’re better off with the 64-bit driver kit since it isn’t that much more, if you want to save a few bucks, the Marlin screwdriver set will work. This only has the T6, so you’re taking a chance on if it will work or not as well.
iFixit's 4 mm aluminum screwdriver handle with magnetic bit socket, knurled grip, and swivel top — plus 64 essential precision bits to tackle sneaky security screws. Görseli
Ürün
Mako Driver Kit - 64 Precision Bits
$39.95
Torx Security precision fixed blade screwdrivers in a handy case with built in sorting tray. Görseli
Ürün
Marlin Screwdriver Set - 5 Torx Precision Screwdrivers
$21.95
Bu yanıt yardımcı oldu mu?
Puan 1
5 Yorum:
thank you very much:)
tarafından
does anyone know what the actual size of the screw is as well? I'm trying to find replacements but I can't tell what the size is.
tarafından
@Talal Hasan Usually Asus is T5 - look up the model and you'll know right away.
tarafından
Guys, I lost them after I removed the screws. Can you tell me their model number? (like M2 * 4). There should be two kinds of screws on the D side.
tarafından
@zpp eBay. Buy a bunch of them for a few bucks, but keep in mind unless you seek out T5/T6, they will be Phillips.
tarafından
Yorum Ekle
Yanıtını ekle
Anton sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 20
Son 30 gün: 91
Her zaman: 19,427
