Ana içeriğe geç
Repair guides and support for tablets produced by Lenovo including the ThinkPad tablet line.
468 Soru Tümünü görüntüle
Gboard is not available so now I cannot sign in. How can I fix this?
I have a Lenovo Tab 10 TB-X103F and today it said Gboard not available. Now I cannot enter a password to open the screen to do anything. How do I fix this? Reboot nor power off then on fixes this problem.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 9
13 Yorum
I have that too but can't go on Windows
tarafından
I am in the same situation - Lenovo tablet, keyboard not working so can't enter my password?
tarafından
Same problem. Can't unlock tablet.
tarafından
me to not been able to sign in since 14th dec come on google fix this problem
tarafından
A soft reset fixed this issue for me! @Per Morten Berg
tarafından
8 tane daha yorum göster
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
This is a widespread problem today. Fortunately, Google has already released an update. If you can’t log in to your device, and you don’t have auto-update turned on, then go to Play store in Windows and push the update to your device.
Update (12/18/2019)
Go to https://play.google.com/store/apps/detai... on a Windows PC (log in with your Google account info if necessary), click on Install (or Installed), choose the device that is locked out, and click Install. Of course, this will only work if the device is online (WiFi or cellular).
Bu yanıt yardımcı oldu mu?
Puan 2
8 Yorum:
I have the same problem, but can't do anything as I cant type my password to open the device
tarafından
how do you push the update to your device
tarafından
same problem and have pushed update to my device nothing has changed gboard doesnt work still
tarafından
I'm the same here. I have three devices so when I go to play store it shows two devices already updated & gives no option to push the update to the locked out device.
It is set up to auto update but very often they don't. You have to go in & push go. But as I can't get passed the password screen I can't do it. The device has been left on 48 hours & still rendered useless.
tarafından
How do you push the update to the tablet?
tarafından
3 tane daha yorum göster
Yorum Ekle
There should be a tiny hole (only big enough for a pin to be inserted) on the side of the device. On my Samsung it's on the top edge, on Lenovo it's on the side. Insert a pin or similar and press. This soft reset allowed my device to install the required update and returned the keyboard to working order. I then immediately removed the password.
Puan 0
Yorum Ekle
Hi I had same problem go on to Lenovo site and it tells you how to reset worked for me I now don't sign in .hope this is helpful x
Puan 0
Yorum Ekle
Yanıtını ekle
potterandy55 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 43
Her zaman: 5,822
