Ana içeriğe geç
2006 Ortası / Model Numarası: A1181 / siyah veya beyaz kasa / 1.83 veya 2.0 GHz Intel Core Duo işlemci
Lines showing on LCD
Hi everybody,I am attaching some pictures of the lines on my sons Macbook,
my question is is this a damaged LCD,LCD driver or something else ..?
I like to be sure before I order new LCD
thank you for your time (big help) !
peter
Resim
Resim
Resim
Bu iyi bir soru mu?
Puan 3
Yorum Ekle
5 Cevap
Filtre ölçütü:
Seçilen Çözüm
It seems to be a bad LCD panel. Does the image change when you apply pressure on the sides of the LCD panel ? You may try first to replace the LVDS (video cable) or double check if the cable is well connected to the panel (and logic board). Also if you want to be sure that the MacBook logic board is not faulty connect the computer to an external monitor and if the video is normal then the logic board should be OK.
Bu yanıt yardımcı oldu mu?
Puan 4
1 Yorum:
sorry rab777hp, I was writing my answer when you posted yours.
tarafından
Yorum Ekle
Looks like a bad LCD, but to be sure, connect to an external display and see if the picture is fine there.
Puan 2
Yorum Ekle
cracked LCD, it might grow larger in time. Pay attention at the way is fixed in hinges so not to get bigger (wrong placement, tensions in lcd)
Puan 1
Yorum Ekle
Definitely a cracked LCD. I am an Apple Service Technician. You can do the replacement on your own if you have a putty knife (slim) and a #00 phillips screwdriver.
Puan 1
Yorum Ekle
And how to do that?? :)
My LCD just cracked!!!
Puan 0
1 Yorum:
Tanja, take a look at the date. this question appears to have been visited last a year ago. It works so much better if you ask your own question. This section works a lot different than your usual "Forum". On here, You can ask question about Your device, and (most of the time) you will receive answers that are specific to your question. Use this link http://www.ifixit.com/Answers/Ask/MacBoo... to post your question, and give as much detail as possible. One more thing you can do, check the Step-by-Step guides for your device by clicking on the tab below the image of the device. You might just find your answer on there. Good Luck.
tarafından
Yorum Ekle
Yanıtını ekle
PiotrO sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 16
Her zaman: 3,924
