LCD NO Backlight - Extra Monitor Works FINE - Backlight Randomly Shine
NEED FOR SURE ANSWER IF POSSIBLE : )
My MBO was working just fine had fan noise then then went to sleep mode then when I attempted to wake it up the backlight was fully off i reseted everything sometimes randomly the screen lights up for a few seconds then back off but once in a blue moon.
What can this be? It works with external monitor just fine keyboard lights up and all.
I CAN SEE with a flashlight sideways everything just fine but no backlight.
What can i test / check to see what the issue may be?
Bu iyi bir soru mu?
2 Yorum
I am experiencing the same issue, however i just replaced the inverter, and my i sight and my keyboard led is working just fine, this is becoming very frustrating... not sure where to go from here
Thanks
lbrockbank tarafından
are you sure about the connectors/wires?
are you sure your left IO board produces correct voltage?
https://d3nevzfk7ii3be.cloudfront.net/ig...
Serjio tarafından
