Ana içeriğe geç
The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
428 Soru Tümünü görüntüle
Spilt Water on Xbox One S
I knocked a glass of water accidentally off of my desk above my Xbox. It wasn't very much but it basically poured right into the fan. I left it to dry for about 8 hours and now it will turn on for a max of 30 second then power off. What should I do? Is there any fix for this?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Try leaving it to dry even longer. I would recommend taking it apart and setting the motherboard at an angle in a dry place. There may still be water on the motherboard under chips.
Otherwise, the power supply might be dead now. If you take it apart and it looks like there’s heavy water damage on the motherboard, then that’s probably not an issue.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
It really hard to take apart and im not sure i'll be able to put it back together after
tarafından
If you don't feel comfortable taking it apart, I would still try leaving it on its side for several days. The only way to truly make sure all the water leaves is by taking it apart unfortunately.
tarafından
Yorum Ekle
Yanıtını ekle
Nate Jakola sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 55
