Ana içeriğe geç
Sony Computer Entertainment tarafından üretilmiş bir oyun konsolu. PS4 olarak da bilinir. İlk olarak 20 Şubat 2013'de duyurulmuş ve 15 Kasım 2013'te satışa sunulmuştur.
Is all hope lost?
Hello,
My ps4 needed a good cleaning, real bad.
Long story short, the power connector cable and the part that holds it down came off with it.
Horrendous!
Normaly i would solder, but seeing as the pad was ripped away at the same time. There is nothing for the solder to stick to.
As the title says, is all hope lost?
Or do i need to get a new motherboard? *cries in expensive*
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
@silverboy fecal matter happens. Get a sharp instrument like a razor, exacto knife or scalpel and carefully remove the green masking from the trace to expose the copper underneath. Then use a thin wire to solder a jumper from the points as shown to the connector. This is one of those times where I would apply a few drops of adhesive after the soldering to the connector. Just to provide a little bit of tensile strength to it. Not a horribly bad repair and it should get your board back on the road.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Silverboy sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 15
Her zaman: 127
