Keyboard and Trackpad unresponsive, liquid damage on logic board
I bought a MacBook air with unresponsive keyboard and Trackpad. I was told it had not suffered liquid damage, so I thought it'd probably be a case of replacing keyboard and or Trackpad with ribbon, but off course when I opened it up, I noticed there were some liquid damage marks underneath the logic board.
I cleaned this out with isopropyl alcohol and left it to dry. I can't see any resistors etc missing off the board. Connectors also look ok visibly. Put it back together and still the same issue.
I know the issue is on the logic board as I've tried another board from a similar MacBook and keyboard and Trackpad came to life.
I'm looking for some advice as to where exactly on the logic board should I be looking for any particular issue relating to the Trackpad/keyboard please?
Picture of cleaned up logic board is attached.
Thanks
Bu iyi bir soru mu?
Can anyone help?
Faisal Gondal tarafından
What is the board model number?
Tim tarafından
Hi
It's 820-3208 A
@optimizelogic are you able to assist with this logic board issue? Thanks
Before you cleaned the board, did you notice any corrosion anywhere?
Tim tarafından
5 tane daha yorum göster
