Ana içeriğe geç
A1708/EMC 3164 — Released June 2017, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar).
547 Soru Tümünü görüntüle
MBP 2017, black bars across screen, display failure.
Hi
My 2017 MBP has been developing a display fault resulting in a large black bar across the screen. This device was purchased refurbished at the start of 2018, and thus the 1 yr ltd warrenty is no longer active, but my statutory rights still stand (EU). From some research here and elsewhere it seems to be common, but not common enough to warrant a recall program.
The device is currently with an AASP, and according to them the GPU or another display component has been fried due to inadequate cooling.
The question is, would you consider this an inherent fault with the device? and has anybody sucessfully had an issue like this rectified without paying for it?
Video:
https://youtu.be/jdgd40N_n_U
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
This issue was covered under a warranty exception after presenting Apple with a tech report / repair quote
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
En Yararlı Yanıt
You need to hook it up to an external monitor to confirm the diagnostic.
Puan 2
4 Yorum:
AASP confirmed this using an external.
tarafından
Fine, as long as you saw it and not just them.
tarafından
More often the internal displays T-CON board has this issue which won't show up on an external monitor. I would double check is you have the grey bar on it.
If the external's image is clean then you'll need a new display assembly, as the T-CON is part of the display via a set of ribbon cables.
As far as fault. In my option this is a design failure as the T-CON board is placed near the heat sink cooling fins. The lack of cooling either because the fans failed or the vents where blocked so air was not able to flow across the fins would be the root cause.
I would press for a warranty exception! As Apple should take responsibility.
tarafından
@danj Thanks for your advice, they did indeed take responsibility for this issue.
tarafından
Yorum Ekle
Yanıtını ekle
padrick sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 384
