Ana içeriğe geç
Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
433 Soru Tümünü görüntüle
iMac 2008 where does this wire goes? Solved
I am putting back together this iMac 2008, but I have no idea of where this cable should be connected.
Thank you
Update (01/18/2020)
ok :-) I found it . it goes into the PSU. Thank you
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Here’s the logic board connections laid-out as you can see the bottom Power button connection is a two pin connector (one of the few) and it is a single wire connection which is what you have. The switch uses the body case (chassis ground) as the other side.
I’m suspecting the system is not turning on as the power button connection is not connected as that’s what I suspect you’ve got here. But it’s not properly routed. You’ll need to pop out the HD to fix this. Press on the Black upper bracket clip down to snap it out and disconnect the three cables, so you can then fix things.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Below the board. I think it is lower SMD component ( assuming the bents on the wire)
Puan 0
Yorum Ekle
Yanıtını ekle
francoborgo sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 52
