Ana içeriğe geç
Released in November 2017, the Oppo F5 is the first smartphone to use an 18:9 display instead of 16:9. In spite of having a 6.0-inch screen, the F5's width is similar to the 5.5" display with 16:9. Models CPH1723 and CPH1727.
41 Soru Tümünü görüntüle
My phone was dropped and screen is not working it's not cracked
My phone was dropped and now the screen dose not work it turns on but screen doesnt light up and the screen is not cracked it has a small crack on the back can someone please help me
Bu iyi bir soru mu?
Puan 0
2 Yorum
Screen cracked please pix kare
tarafından
@vijaydasar follow the instructions given in the answer. You need to replace the screen
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi,
Just because the screen is not cracked doesn’t mean that there isn’t an internal problem in the screen (e.g.broken connection) due to the fall.
With the phone turned on, try shining a torch at an angle close to the screen and check if you can detect an image at all. It will be very faint if is there at all.
If there is an image there then there is a problem with the backlighting in the screen but this could either be a problem in the screen or the systemboard
As a DIY repair to prove if the screen was faulty or not you would need a replacement screen that you could temporarily connect to check whether it is the problem or if the problem is in the systemboard
If there is no image there then phone would have to be opened and inspected as to what the problem may be.
Either way the phone will have to be opened
Here’s a link to a video that shows how to replace the screen in the phone which may be of some help.
If this is too daunting a task, contact a reputable, professional mobile phone repair service and ask for a quote to repair the phone.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Yanıtını ekle
David Soulis sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 23
Son 30 gün: 126
Her zaman: 2,682
