Ana içeriğe geç
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1169 Soru Tümünü görüntüle
No display after repair
I've googled everywhere, and scoured this site for an answer to my problem. My problem IS like a lot of the other questions, but the fixes don't work. I can turn the phone on, hear sounds when I plug it into my MacBook, shows up in iTunes, and it vibrates when I flip the silent switch. The only problem is having no display/backlight.
My friend brought me the phone after finding it laying on the ground with a cracked touchscreen. Everything else was perfect on it, display lit up and everything. I replace the touchscreen, reconnected and it worked fine! Here's the kicker. The Home button wouldn't work, so I pulled it apart to fix the button contact but the #3 cable came loose. I have all the flex cables secured with dental wax (random, but it works and isnt too messy). I tried:
A. Holding Home+Power for 10s or until Apple logo shows
B. Removing the logic board for 5-10 min away from the battery.
C. Doing a full restore
Sorry for the long post, just wanted to give as much info as possible. Can anyone help me? He needs the phone back in a few hours, and I'm at my wits end. Also, this is NOT my first repair on an iPhone 3G. I have had MANY successful repairs.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
choices are..wrong LCD (3gs instead of 3g) damaged connector 1.. LCD is faulty or is now broken. try keeping the board out for longer (until board has cooled.. that's the few hours you have left)
Bu yanıt yardımcı oldu mu?
Puan 3
3 Yorum:
The LCD is the one that came with the phone, I only replaced the digitizer. The flex cables all appear to be perfect.
tarafından
Plus, like I said, the display worked fine before I pulled it back apart to fix the button.
tarafından
Honestly been in your situation before maaaannny times. Take the board out, walk away, watch tv, walk the dog, play ball... Leave the board for ages.(left 1 overnight I was so annoyed!!) then try again. I know you've done it before but sometimes it's just not long enough. Just because the screen worked before doesn't mean it isn't broken now either..
tarafından
Yorum Ekle
i had the same problem friend,
for me i was a hardware issue problem
you have to replace the two inductance
https://rapidshare.com/files/2043909429/...
Puan 1
2 Yorum:
thats for a 3gs. the backlight is built in to the screen on the 3g. there are fuses on the rear of the logicboard which may help, but I believe most likely this is the connector 1
tarafından
I know the 3GS has that coil that fries when you work on it while its still on, 6R8 I believe, but I havn't seen anything like that on the 3G. As far as i can tell there aren't any blown fuses. If it was a backlight problem, I would still be able to see stuff on the screen, but I don't. The #1 flex looks fine, all the pins are fine, and the connector is fine. Since I have it held down with wax, I don't think that's the problem.
tarafından
Yorum Ekle
Yanıtını ekle
Brad Boal sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 13
Her zaman: 3,238
