Sanyo tv has lost all channels and won't auto or manual tune
I have a Sanyo LED-42XR10FH which has suddenly lost all channels and won't auto tune or manual tune. Powers on fine, other devices connected work, just no channels. I have tried disconnecting from wall, factory resetting, checked all cords, replaced coaxial but continue to get a no signal message when trying to manual tune. Old tv but has worked perfectly until now.
Bu iyi bir soru mu?
4 Yorum
All I have is an antenna hooked up to my TV I cannot get any picture when I go into menu I cannot find where to auto scan to add channels to my TV please help
Elklady tarafından
@Elklady
What is the model number of the TV? This information is usually found on a label at the back of the TV
usually to set up the TV you look in Menu > Setup.
If you had the TV connected to a cable box before you may have to change a setting from "cable" to "antenna". It should be located inthe Setup area of the menus but maybe not.
The model number is needed to help you further.
jayeff tarafından
How do I get channels back if TV wont program them?
tabbaphil tarafından
Hi @tabbaphil
Check the comment above yours here and see if that helps
jayeff tarafından
