Ana içeriğe geç
Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo processor
310 Soru Tümünü görüntüle
Won´t power on, need boardview
So a costumer bring me this iMac A1311 because the device don´t power on. We live in Varadero, Cuba, so the ambiental contamination of the sea its pretty destroying (the salt) rustting almost everything.
I clean up the logic board and still wont power on.
I need the boardview of the logic board : 820-2494-A, so I could continue to check the device.
And if anyone have possible solutions…
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
4 Yorum
Why do you think it is the logic board? It could be the power supply. Have you tried taking LCD off and check the board diagnostic LEDS? Is anything on?
tarafından
@annielservitec absolutely no LED you have a power problem
The schematic etc. does not address the power supply.
tarafından
Replace the power supply inside the Mac, but first check the power cable going into mac, and check the fuse inside the plug (if you have one)
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@annielservitec you need to know that those are copyrighted and thus we will never post any off this on here. You will have to give us more information so that we can try to assist you with the problem. Number one suspect would be the power supply.
Bu yanıt yardımcı oldu mu?
Puan 2
3 Yorum:
Hi, I was checking this post : PSU/logic board pinout voltages.
And I follow your instructions for checking the PSU and i have the 12V in pin 4 and 3V in pin 12, but I still have no powering on nor LEDs signal. I also check the power button connector and there´s no 3V. I believe that I have a bad logic board
tarafından
yes,that might just sounds like the logic board since your PSU seems to show the right voltages.
tarafından
I guess I´ll have to check the logicboard
tarafından
Yorum Ekle
Yanıtını ekle
Luis Anniel sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 4
Her zaman: 186
