iMac 27" 5K LCD Issue After Changing Power Supply
Hello,
I had been experiencing issues with my Late 2015 iMac 5K Retina EMC 2834 where the machine would suddenly just shut off intermittently and would require the AC adapter plug to be removed from the power source and plugged back in before it would be able to restart. After searching iFixit, I had become aware that I probably had a faulty power supply board and that it should be replaced. I ordered the replacement board along with tools and the LCD adhesive kit.
The other day I went through the process of replacing the power supply and after finishing and putting everything back together, I turned on the machine to find that the LCD display is all messed up. There are horizontal lines in some places, vertical streaks in others, image ghosting and completely black on one side. I’ve attached a picture of what it looks like:
Even though I was careful during the repair, I did have a moment where I accidentally lifted the display a little too far with it still connected to the board when I was putting everything back together. It wasn’t much but maybe enough to break something, perhaps the cable or the connector on the board? I have connected and external display and it worked perfectly. Just to clarify, the iMac display itself worked perfectly before I removed it and put it back so it wasn’t something that was faulty, but something that I did during the power supply replacement.
I’m just trying to get an idea of the most logical reason I would be getting this issue and what the first courses of action should be? I don’t want to simply purchase and replace the entire LCD unit unless it actually needs to be replaced which I don’t know. If it’s likely a cable or connector, I would like to start there first to save any unwanted expenses.
Thanks in advance for any input.
Bu iyi bir soru mu?
