Ana içeriğe geç
Guides for the Wi-Fi version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
220 Soru Tümünü görüntüle
Why won't my iPad turn on?
Since my iPad turned itself off, while I was using it, I’ve tried resetting it and connecting to computer- neither have helped. When I hold in power and home button the logo screen flickers on, for varying amounts of time and sometimes with part of the screen darker then the rest, and then turns off again before the lock screen.
Update: I managed to turn it on for a few moments, the screen was very dark except around the home button where it was lit up more- it then switched itself off again.
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
You have to determine if this is a battery/charging issue or something else. Try these steps to help isolate the issue (in order):
  1. Always try another Lightning cable and charger, preferably Apple original or MFi certified units. Does an iTunes enabled computer recognize the device?
  2. The Lightning cable 8-pin connector should be sitting flush with the housing and completely inserted. If it is not, there could be lint/dust/debris inside the port impeding a proper connection. You can clean it out with a toothpick, fine point tweezers or a dental pick. Just be careful not to damage the pins inside the Lightning Port.
  3. You can use a USB Ammeter to determine if the device is really drawing current when it says it's charging. If it isn't drawing current, then it could be a bad charge port or battery.
At this point, you need to get back to us with more info on your troubleshooting. You may also need to start replacing stuff, which means opening your device. Check out this guide to see if you are comfortable with the work required.
Bu yanıt yardımcı oldu mu?
Puan 4
Yorum Ekle
it has died or the batry died
Puan 0
Yorum Ekle
it has died and you can take it to i place to fix it
Puan 0
Yorum Ekle
Yanıtını ekle
particleman sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 265
