Ana içeriğe geç
Small media streaming device that plugs directly into your TV's HDMI port. Originally released by Amazon in November 2014. The latest version comes with a voice-activated remote.
20 Soru Tümünü görüntüle
fireoscaptiveportal generate_204 Setup Firestick
I’m trying to setup my new Firestick but it keeps getting stuck on the joining network page. The screen shows a white box and the message includes a link to fireoscaptiveportal generate_204
Any ideas on what to do please? My internet is working perfectly on my other devices.
Bu iyi bir soru mu?
Puan 87
19 Yorum
Any solutions to this issue?
tarafından
I get the same screen, but in the middle of watching something. Rebooting everything seems to help but is really annoying.
tarafından
net::ERR_NAME_NOT_RESOLD
tarafından
How to setup my WiFi Repeater?
tarafından
What is the username and the password for my WiFi Repeater
tarafından
14 tane daha yorum göster
Yorum Ekle
9 Cevap
Filtre ölçütü:
Seçilen Çözüm
which type of frequency your wifi works on? 2.4 or 5 ghz?
If your router is syncing the two then there might be your problem (you should change the setting of your router to get out 2 ssid one for the 2,4 and one for the 5ghz and then you try to connect on one or the other to see which one works
Bu yanıt yardımcı oldu mu?
Puan 56
11 Yorum:
I do not want to change any settings on my router as ‘all’ other devices and services appear to work without an issue, as does another fire stick on another TV, any other ideas?
Thank you,
tarafından
I agree the television works perfectly with the aerial by I want to use the other facilities as well
tarafından
i reccently changed passwords on my wifi
tarafından
i changed password recently, cause could be time of day or due to my amount of activitie?!
tarafından
This answer is completely useless and does not address the actual issuel
tarafından
6 tane daha yorum göster
Yorum Ekle
It’s the BT home hub smart setup. Go into advanced settings on the router and disable smart set up. Everything will work perfect after!
Puan 8
6 Yorum:
je ne comprends pas votre langue !
tarafından
i dont know how! everything wAS Fine, until i changed psw"s all other devises work ok!
tarafından
it tells me ; access blocked!
tarafından
Press the three lines on your fire stick remote and then press select and forget the network then find the network again and enter your password to log into your router again and go to the home screen on the fire stick and they should work if it doesn't work the first time repeat the process until it does this worked for me today on January 24th 2022 good luck
tarafından
Yea. Worked on reboot of the device
tarafından
1 tane daha yorum göster
Yorum Ekle
i made the stick “forget’ my router and reconnected and it worked
Puan 7
12 Yorum:
I tried but that didn't work either. I even tried with phone hotspot but it didn't work
tarafından
it is working now thanks for help
tarafından
Just do forgot network and reconnect it. It will work. I have did and successfully connected.
tarafından
Same issue .. My solution was forgetting the network, resetting the firestick and reconnecting to the network again :) .. works fine now!
tarafından
by resetting the fire stick you mean ?
tarafından
7 tane daha yorum göster
Yorum Ekle
Unpaused firetv please I want to watch tv
Puan 4
Yorum Ekle
bonjour, pour que je comprenne , il faudrait, m’écrire en français, je ne comprends pas votre langue, que vous chercher à nous imposer, tout le monde ne parle pas anglais, merci de revoir votre copie
Puan 2
2 Yorum:
bonjour, je voudrais que nous donne la solution pour installer OQEE by free avec amazon fire tv stick qui rend soin disant une ancienne tv en en téléviseur Smart , merci
tarafından
eu ce problème aussi le 24 janvier 2022. SOLUTION : Réinitialisez le Firestick en usine et cela fonctionnera. Et si vous ne savez pas comment réinitialiser, maintenez simplement la flèche droite + le bas de la télévision (en bas) pendant 10 secondes et il vous demandera de réinitialiser le firestick. Merci
tarafından
Yorum Ekle
bonjour
moi jai le meme probleme. sauf que jarrive pas a me connecter a internet. cest ca le probleme. je suis dans 1 hotel. le meme depuis 2 mois. ca fonctionnait parfaitement puis soudain bam non!. le portail de lhotel saffiche, je peux entrer mon email mais quand je fais connection: il mamene a la page blanche err not responded. fireportal generate 204. jai tout essayé: débrancher la firestick, vider les caches, vider les cookies, essayer de passer par silk( mais je suis pas capable puisque je nai pas dinternet). a laide!!!!!!
Puan 2
Yorum Ekle
No puedo usar mi fire tv porque no conecta el internet
Puan 2
Yorum Ekle
Don’t know why it’s not working
Puan 0
Yorum Ekle
All of my TVs say paused? Anyone have a for this?
Puan 0
Yorum Ekle
Yanıtını ekle
Sam sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 24
Son 7 gün: 225
Son 30 gün: 901
Her zaman: 67,634
