Screen replacement ways to teardown without heat gun
Is there a way to teardown for screen replacement with out the use of heat gun to unstick qlue
Bu iyi bir soru mu?
Bu iyi bir soru mu?
hairdryer works as well as a hot air gun or these guys sell a microwavable sack thing that you microwave and is designed for resting on the screen to melt the glue i think its called an iopener, but really you just need some heat to soften the glue a hot water bottle would work just as well as long as you make sure its dry
Bu yanıt yardımcı oldu mu?
Any gentle, non-focused heat source should be fine. A hairdryer, space heater or radiator will all work. Just be careful to not get it TOO hot, otherwise you could damage the motherboard or LCD.
I personally use a gel hot/cold pack from the drug store. Microwave the pack then place on back of phone for a couple minutes and the back comes off in one go.
Son 24 Saat: 9
Son 7 gün: 76
Son 30 gün: 369
Her zaman: 10,171
