Ana içeriğe geç
Repair information for printers made by Canon.
Printer is showing error code E22
I have a Canon pixma mp160, I was scanning and coping right from the printer not from the computer. I turned it off and about an hour later I needed to scan and printer again from my printer. It sets up as always the when I push to scan and print it does an error code E22. When I try and use my computer to print from it gives me service error 5100. I can't figure out what these error code mean. I have unplugged the cord and waited for an hour and plug it back in and once it sets up and sits there waiting to use the rollers start again then it goes to the error E22. What is the cause of the E22 error code? Thanks
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I had the same error and it got fixed only by pushing the carriage back to its starting place when I got the error (there was a small distance) and turning off the printer. It seemed that it lost its coordinates.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Been trying to fix my printer for weeks, this was the issue. Thank you.
tarafından
Yorum Ekle
Apparently, Error Code E22/5100 is an issue with the carriage movement. Something might have jammed it up. Check for any paper jams, and try out this guide to see if these steps help at all
https://smartprintsupplies.com/blogs/new...
Puan 0
2 Yorum:
There are no paper jams. A few time the roller feeds the paper all the way through when it's turned on and setting up. Then it is also feeding it a little ways and reverse it backing out when it's warning and setting up. It will also feed the paper when setting up when turned on and I have to pull it out, but I don't tear the paper. I even removed and clean that whole part that the ink carriage sits on when not in use.
tarafından
When I turn the printer on I can see the ink carriage moving back and forth when setting up.
tarafından
Yorum Ekle
Yanıtını ekle
Sherry sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 21
Her zaman: 3,314
