Ana içeriğe geç
The Huawei Honor 8 is an Android smartphone released in 2016 that features a 5.2-inch 1080p display, 4GB of RAM, dual 12MP camera sensors, a fingerprint sensor, and a USB Type-C port. Model : FRD-L04.
48 Soru Tümünü görüntüle
Screen Replacement ( To Glue Screen And Frame)
Can I use any Adhesive Gum like Fevicol to Glue my Screen and Frame Or should I use any particular Glue like B-7000 ?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@pro_gamer this “The best way to secure the new screen is with a sheet of custom-cut double-sided tape. Apply the tape to the back of the screen, then carefully feed the display cable through the frame. Align the screen and press it into place.
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.” from Huawei Honor 8 LCD & Digitizer Replacementhere. Any other glue will be a PITA to remove if you need to replace it again.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
how do you replace the new screen, with band or glue
tarafından
Yorum Ekle
Only use adhesib t8000 glue or gum.My
experience about 10 years its good.
Puan 0
Yorum Ekle
Yanıtını ekle
Anish Kusunuri sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 13
Her zaman: 578
