Ana içeriğe geç
2015 yılında piyasaya sürülen ASUS X540s, HDMI video çıkışı sağlayabilen dahili bir grafik işlem sistemine sahip 15,6 inçlik bir dizüstü bilgisayardır.
Laptop not turning on
Hey guys, my asus X541UA not turning on.
1.not turning on
2.not light charging indicator and not charging
3.sometimes its on, but turning off few seconds.and also connect charging and lights on
Could you please tell me what the problem is?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
5 Yorum:
If it works with the charger connected then the battery is defective.
tarafından
Thanks for replying. I removed battery but same thing happen.
tarafından
@tharaka maduwanthi
Tharaka, Do you know if the charger is good?
tarafından
Yes. I on my laptop without connect charger it not response.but after I connect to changer its on and immediately off.That happens twice or three times.after it not response connect charger and not light charging lED.
tarafından
@tharaka maduwanthi
Try this:
Remove battery.
Connect a different charger, say borrow a friends, with the same voltage.
Does the laptop turn on?
Does anything appear on the screen?
When troubleshooting you want to eliminate possible causes so in this case we are trying find out if the battery or the charger is the problem
If it is not the battery or charger causing the problem then it is something on the computer's main board.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Hi Tharaka,
As you have encountered A PC shutting down suddenly, which is usually a sign of a power problem and can be extremely frustrating. This can cause you to lose whatever you're working on, but it may also be a sign of damage to the computer itself. Generally, when a computer powers down on its own it's due to the power supply, malware, overheating or driver issues.
Additionally, an unexpected shutdown of system can make your data inaccessible as well. The good way to overcome this problem and recover files after unexpected shutdown is by using a recovery tool that supports Windows PE.
Before locating the problem, make sure you backed up your computer all the time.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
tharaka maduwanthi sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 12
Her zaman: 1,263
