Ana içeriğe geç
Safari can’t find the server
I recently found an iBook G4 and I put an Airport Card in it to connect to my home wifi. On the Network section there is a green dot next to AirPort. The Mac OS X is 10.3.9. Do I need to upgrade to Leopard before Safari will work? Or what else do I need to do?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum:
Will it connect via an ethernet cable?
tarafından
Yes I can via an ethernet cable but only some sites come up. When sites to come up they aren't complete and no pictures.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
You need to use a browser other than Safari. Most web servers these days use secure connections (https) which may be too advanced for Safari to comprehend. If you can upgrade to 10.4 then I’d recommend TenFourFox, otherwise look towards iCab (v4.9 is the latest that’ll run on 10.3).
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
Can I upgrade to 10.5 then download another Web browser?
tarafından
Yes. I'd still recommend TenFourFox in that case. Be aware that there are different builds of TenFourFox depending on your processor, so be sure to download the correct version for your machine.
tarafından
Yorum Ekle
Yanıtını ekle
Ryan Mueller sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 11
Her zaman: 521
