Ana içeriğe geç
16 Eylül 2016'da satışa sunulmuştur. Model 1660, 1778 GSM ya da CDMA olarak 32, 128 ya da 256 GB kapasitelerinde ve Altın Gülü, altın, gümüş, siyah ve simsiyah renklerinde satılır.
2264 Soru Tümünü görüntüle
Why is my iPhone 7 reboot randomly?
I have an iphone 7 that is restarting randomly. I noticed that the phone is rebooting when i plug it to charger, also when this happens tha phone is getting hot, that doesn't always happen. It’s shutting down and restarts, then i need to enter passcode an then it happens again. I checked the logs and i find the following error.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
An iPhone that randomly restarts when not using any apps usually indicates a parts problem. The two main parts that will cause this are battery and dock connector.
Forget the error report and install a new battery. If it still shows the same symptoms try another dock connector.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
I disconnected the dock connector and i tried with another battery, same problem. I will try a new dock connector.
tarafından
If it still shows the same symptoms with a new dock connector you can rule out a parts issue and move to the logic board charging circuit. You will need to have some microsoldering experience and equipment to resolve the issue.
tarafından
Yorum Ekle
Yanıtını ekle
Alex Savu sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 60
