Ana içeriğe geç
The fourth iteration of the popular 7" Galaxy Tab line of Samsung tablets.
136 Soru Tümünü görüntüle
Micro USB port is worn.
The micro USB port is worn or bent, such that it will only charge if the cable is held at just the right angle. And data transfer is out of the question! Is this a simple fix, or would I need to change out the whole motherboard?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Watts Isnaim if your Samsung is indeed a Samsung Galaxy Tab 4 7.0 you will need to remove the motherboard. The charging port is soldered into the motherboard. Not an easy task but if you know how to do some decent soldering you can probably do it. Use this guide Samsung Galaxy Tab 4 7.0 Motherboard Replacement to remove the board and use something like this video to see how it is being done. Replacement ports are available at places like this and many others.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Watts Isnaim sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 6
Her zaman: 58
