Tip of the screwdriver stuck in the screw hole
Pretty straight forward. The tip from an iFixit kit got stuck in the screw hole while I was trying to disessemble it. The hole is way deeper then I thought it would be and now almost the whole tip is inside it. Any idea how to take it out without destroying the controller?
Bu iyi bir soru mu?
Puan
0
I know it’s a really old post, but I’m facing the same issue currently and have no idea how to fix it. The magnet pull tool from iFixIt did not work and I don’t want to damage the bit nor the controller.
Did you solve this?
Eduard Draghici tarafından
Try using a pair of tweezers. Flip it over and use the tweezers to try and work it loose so gravity will make it fall back out.
brandon k tarafından
