Ana içeriğe geç
Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
382 Soru Tümünü görüntüle
Unexpected Shut Down after RAM Upgrade
After purchasing 16GB (4x4GB PC3-10600 SODIMM) of RAM from OWC and installing, the computer seemed to be operating fine. The first unexpected shut down occurred about an hour after the install and has kept happening intermittently since then.
I’ve used disk utility to confirm the drive is in good working order and installed all possible operating system updates. Any suggestions??
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Take the SO-DIMMS out and carefully wipe the contacts with a new pink pencil eraser (not dried out) go with the grain of the pins one stroke per pin to make sure there is not oxide build up, then use a cotton swab with reagent grade 85% isopropyl alcohol.
Try only installing two SO-DIMM and then try the other two.
Otherwise you’ll need to return the RAM to get another set.
Bu yanıt yardımcı oldu mu?
Puan 1
3 Yorum:
Thank you thank you thank you!
tarafından
@princeunicorn - Did cleaning them help?
tarafından
It did indeed! I ended up using an eraser first, followed by the rubbing alcohol. The computer seems to be running perfectly.
tarafından
Yorum Ekle
Yanıtını ekle
Luke sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 254
