Ana içeriğe geç
Repair and disassembly guides for Brother printers.
352 Soru Tümünü görüntüle
Brother HL2270DW Reports Paper Jam or No Paper
Printer shows Orange error LED. Supposed to mean out of paper or paper jam. Trouble is, there is lots of paper, and there is no jam. Printer works fine in manual feed. Will not feed from paper tray. Rollers have been cleaned. Any ideas how to get the LED to turn off and enable printing from paper tray?
Drum and toner are brand-new .
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
1 Yorum
I had this printer for many years and never had a problem with it, printing large files. I had to move things around, and when restarting recently it just did not want to work at all, never got a sheet through. Bought another newer unit on EBAY, and it does the same. I believe the newer drivers or program does not allow enough time for the paper to load. I would like an original driver. Maybe I have the the floppy I started with. In all my years I just loaded the tray and forgot about IT! The new driver is not even Brother.......OH BROTHER!! TOM
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
The Real Answer can be found here
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
bait & switch--they just want to sell toner. don't waste your time
tarafından
Yorum Ekle
Please check the back panel of your printer, may be there is any some piece of paper available inside the printer, that’s why you are getting this error.
How to fix brother printer paper jam issue.
Puan 0
Yorum Ekle
As @theprinterman alludes to above, the real problem is something called the “drive gear engagement arm” - and if you’re feeling even *slightly* handy, you can fix this - with nothing more than a spudger (or a butter knife).
See here: HL-2280DW paper feed not working
Puan 0
1 Yorum:
FIXED! Thank you so much.
tarafından
Yorum Ekle
Yanıtını ekle
David Bogart sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 27
Her zaman: 2,690
