Check engine code 11 can’t find problem
97 Jeep GC engine light code 11 . Crank/cam position sensor. Chokes out while driving like the timing is off. Replaced crank position sensor , cam position sensor , distributor, spark plug wires , solenoid , catalytic converters , computer , map sensor , idle air control sensor , timing chain. getting 5 volts to cam position sensor, can’t find any shorts in wiring. Am totally stumped. 4.0 engine Limited 30k on rebuilt motor , had trans leak fixed and been this way since. Could trans have anything to do with it ? Any ideas ?
Bu iyi bir soru mu?
