Ana içeriğe geç
A clothing iron, also called a flatiron, is a heated surface used to remove wrinkles from fabric.
85 Soru Tümünü görüntüle
How do I disassemble a Philips GC4910/19 PerfectCare Azur Steam iron
When I use the iron, it intermittently trips the rcd. There is a single screw at the back of the handle behind the cable that I have taken out but there appears to be nothing else to remove to get inside or to get the part out that the screw was securing at its top.
Can anyone help.
Thanks
Bu iyi bir soru mu?
Puan 0
2 Yorum
'fraid not. It's for an older model that strips down from the front. Tx anyway.
tarafından
My iron just stopped heating. It was coincident with descaling but not sure if that means anything. The suggested video was not helpful.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
See if this guide will help you:
Phillips Azure Steam Iron Disassembly
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
The next thing you need to do is to remove the blue decorative cover that is over the two lower screws at the back of the iron. I am not sure how you do that without breaking at least some of the small tangs that hold it in place, but it’s not anything but decoration so not a huge deal.
After that, the other thing that isn’t intuitive is removing the top bit of the handle. This is held in place by 4 tangs on each side. I did it by a combination of working a flat blade screw driver at the seem between the upper and lower part of the handle and wrapping a pair of pliers with a cloth and squeezing the top part together while pulling it from the lower part of the handle.
q
Puan 1
Yorum Ekle
Yanıtını ekle
Rob FJ sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 16
Son 30 gün: 50
Her zaman: 1,894
