Ana içeriğe geç
Repair guides and support for laptops manufactured by MSI.
Is my ssd upgradeble
hi i have a MSi GL65 95D
but i lack storagespace
i only have a 512 GB SSD
is it possible to replace it or add another
@dasrepair this is how my laptop looks like inside
I've accidentally spilled some soda on the keyboard so some of them are a bit stuck
Bu iyi bir soru mu?
Puan 0
2 Yorum
Are you still looking to add additional storage?
tarafından
no i have added a 1 tb crucial ssd
i need to replace my keyboard
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
yes sir it is. Here is a guide and an opening for you
https://www.youtube.com/watch?v=hocNUfez...
Bu yanıt yardımcı oldu mu?
Puan 2
4 Yorum:
Hi @dasrepair ,
I also saw this one but it is not for a GL65 95D it is for a GS650.
The GL65 95d is very new. It looks like it has only been released for about 4 months, so opening it up will void the manufacturer's warranty
tarafından
opening it up does not void it. There will usually be a sticker above a screw or a part that says if removed MFW will be voided. From the Manfacture site it only has a M.2 nvme slot. I upgraded a decent amount of msi laptops in my shop. The newer models usually have the slot on the opposite side of the motherboard underneath the keyboard. Which is a pain sometimes but not too bad. Regardless upgrading that storage the hard drive its self is expensive.
tarafından
@akarpti
You can also see from MSI that your model does also allow for a 2.5" drive. https://www.msi.com/Laptop/GL65-9SX-GTX/...
The factory box should also include a sata connection for that 2.5" drive. If you are looking for SSD mass storage then I recommend the Samsung 860 QVO; otherwise Crucial, Samsung, WD, or Kingston's UV line SSDs are highly recommended. I would definitely do a bit a research if you are concered.
-Steve
tarafından
The sticker is for MSI to check for end user damage in the US. They legally can't void the warranty - it's a bad scare tactic at best.
tarafından
Yorum Ekle
Yanıtını ekle
Emil lind sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 424
