Ana içeriğe geç
Spotify on an old iPod?
Is there a way of any sort to have access to Spotify on an iPod Nano 3rd gen (A1236)?
I think the major problem would be to have it connect to a Wi-Fi network.
Maybe a possible solution is to make the iPod be a piggyback of a mobile phone where you have Spotify, but idk.
Problem is Spotify won’t let you sync your iPod when you connect it to your pc so there’s no way to download your entire Spotify library to your iPod.
I found there are some programs that claim to be able to do it, but they have two major problems:
1 - you have to select each song and drag it onto the program;
2 - they are quite expensive (30-40$) whereas most iPod mods can be done with less expense.
Big thanks to anyone who’ll answer!
Bu iyi bir soru mu?
Puan 1
1 Yorum
No. There is no wifi capability or way to install new apps
tarafından
Yorum Ekle
7 Cevap
Filtre ölçütü:
Seçilen Çözüm
Sadly, the iPod just doesn’t have the needed ability to stream Spotify as well as have a way to unlock your downloaded library as its limited to a tethered connection. You’ll need to live with $40 solution.
A cheap iPhone is the best you can do and run the Spotify app Spotify: Music and Podcasts
Bu yanıt yardımcı oldu mu?
Puan 1
4 Yorum:
A cheap iPhone OR iPod Touch
tarafından
Sure an iPod Touch will work but it will be limited to loaded content and you will need to authenticate via WiFi. You need the cellular connection which the iPhone has for streaming content when on the go. Consider the storage space your library will need Vs streaming.
tarafından
@nick - I have an iPod Touch which I use when I workout with bluetooth headphones. I only have my workout music and a few podcasts using iTunes.
tarafından
@angelodaniels - Correct! You need a unit which can connect to the Internet.
tarafından
Yorum Ekle
The compatibility of iPods is varied, able to play audio files in the format of AAC, MP3, PCM, Apple Lossless, FLAC, and Dolby Digital. However, all music from Spotify is streaming content protected by digital rights management so Spotify music is only available within Spotify itself. That’s why you cannot listen to Spotify music from iPod.
If you want to reach Spotify music to iPod, the best choice is to remove the private content copyright from Spotify and convert Spotify music to iPod supported audio formats. How to do this? To achieve it, you may need Tunelf Spotify Music Converter for iPod. Then you can download Spotify music to an iPod for listening.
Puan 1
Yorum Ekle
Spotify does not support music streaming on iPod Nano, Classic, or Shuffle. I‘ve read a post in the Spotify Community, saying that some old generations of iPod Touch can install the old Spotify app which stopped updating. Not sure whether this method is available for iPod Nano. Apologies that I cannot find that post now.
https://www.audfree.com/spotify/sync-spo... This article here might be helpful to you. I use the Audfree music converter for Mac to download Spotify songs and then sync them to my iPod Classic.
Puan 0
Yorum Ekle
As I know, Spotify doesn’t support Pod Nano, Classic, or Shuffle. But it is still possible to listen to Spotify music on the old generations of iPod Touch by using a little trick.
And this is how I listen to Spotify songs on my iPod Shuffle. First, install the Spotify Converter on your computer. Then use it to download music from Spotify into the local folder. Last, move the local Spotify tracks to your old iPod Touches. These local Spotify tracks are playable without the Spotify app.
You can refer to this article to get more details: https://www.audkit.com/spotify-music/spo...
Puan 0
Yorum Ekle
If you want to download Spotify music to iPods, you need to use a third-party Spotify music converter.
With UkeySoft Spotify Music Converter or TunesBank Spotify Music Converter, either free or premium subscribers can download and convert Spotify songs, albums or playlists to MP3.
https://www.ukeysoft.com/spotify-music-c...
https://www.tunesbank.com/spotify-music-...
UkeySoft Spotify Music Converter can download and convert Spotify music songs, playlists, albums, and artists to MP3 listlessly, so you can play Spotify music offline on any devices. Besides, you can use UkeySoft Spotify Music Converter to convert Spotify music to M4A, FLAC, WAV format according to your need. After download Spotify music as MP3 files, you can enjoy Spotify music offline with Free or Premium account, or transfer the downloaded Spotify music to any device for playing offline.
Puan 0
Yorum Ekle
I just came across your post and wanted to share some ideas. The iPod Nano series doesn't have the capability to run third-party apps like Spotify. However, you can still enjoy your favorite tunes by transferring your music files from your computer to your iPod Nano using iTunes. It may not have all the streaming features of Spotify, but you can still rock out to your own personalized playlists. In addition, for those who are looking to increase visibility and engagement on the Spotify platform, there are reliable providers out there that offer the option to buy spotify plays. These services can help boost your play count and potentially attract more listeners to your music.
Puan 0
Yorum Ekle
iPod Nano doesn't support Spotify app and you can install third-party apps to stream music.
You should use DRmare Software to download and transfer Spotify tracks to iPod Nano for offline playback via iTunes.
Puan 0
Yorum Ekle
Yanıtını ekle
luca.rainoldi sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 16
Son 30 gün: 69
Her zaman: 4,495
