Ana içeriğe geç
Microsoft's third-generation Xbox game console, released November 22, 2013.
Sync issues on Xbox One Console
Okay, I’ve just replaced a faulty hard drive in my old-style Xbox One. In doing so I had to go into factory settings by pressing the button and the eject button, so I know there is no physical problem with the button. However, now when I press the button, the Xbox will not flash to sync a controller. I’ve tried syncing the controller using a USB cable, still no joy. There are no issues with the controllers, I have two Xbox’s.
It’s really strange the button works for factory settings, but not syncing.
Any ideas anyone.
Thank you in advance.
P.S.
I don’t think it matters, but it is a Forza limited edition, which is why I don’t want to send it to Microsoft to be replaced.
Bu iyi bir soru mu?
Puan 0
1 Yorum
Thanks Steven.
I’ve tried that, no luck.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
I figured out the problem. I’m such an idiot. I forgot to plug the wifi board back into the motherboard.
DOH!
That is why it wouldn’t sync even with the USB cable.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Have you tried doing a hard reset?
  1. Holding the power button down for 10 seconds while the system is on will perform a hard reset.
  2. The Xbox One Will Switch Off.
  3. Power on the Xbox One again. You'll see a green start-up screen.
  4. All your data is preserved, but the cache will be cleared and settings may reset.
That has worked in the past when I had this issue.
Puan 0
Yorum Ekle
Yanıtını ekle
Craig Veale sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 19
Her zaman: 209
