No display on my Huawei Mate 20 Lite
Hi,
I have no display on my phone when I press the power button. I have attached a video of the problem
Your help is much appreciated
Thanks
Bu iyi bir soru mu?
Hi,
Thanks
Bu iyi bir soru mu?
did you break the LCD screen it could need a new screen or battery
Bu yanıt yardımcı oldu mu?
Hey Adeel ;
I can see the back light is being blocked by full contrast from display . Did it drop hard? was screen replaced ? If it were me I would find a tear-down video and double check any of those ANNOYINGLY small connections . Dunno if it will be a case of reflowing the “lead” free solder with heat . Severe drop can crack mobo tho .
Factory reset procedure should not be bothered with , unless you dont care and are curious if it helps . I dont think that would do anything .
PS ! caveat ! reset may cure accidental screen bright down to zero . In a dark room can you see any hint of images ?
Good luck
Hugh
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 1,896
I have the same problem. Did you solve it ?
serbmilan tarafından
