Ana içeriğe geç
Acer entered the world of laptop computers in 1997 when it purchased Texas Instruments' mobile PC division.
1682 Soru Tümünü görüntüle
5.9 GB Ram only usable out of 8 GB Ram. How to fix?
I’m having an Acer Nitro 5 Ryzen 5 Quad Core - (8 GB/1 TB HDD/Windows 10 Home/4 GB Graphics/AMD Radeon RX 560X) AN515-43 Gaming Laptop  (15.6 inch, Obsidian Black, 2.3 kg) laptop. It shows 8 GB Ram. But I can use only 5.8 GB Ram usable. It is having AMD Radeon RX 560X 4GB graphics. But it’s primary graphics is AMD vega 8 graphics having 2 GB graphics. 2.1 GB of RAM is hardware reserved. How can I get 8 GB of RAM fully usable?
Bu iyi bir soru mu?
Puan 2
1 Yorum
you have to turn off the igpu
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Go to the BIOS and check it , it is sharing the memory with the VGA even though it is showing dedicated VGA
but if you reduce the VGA Memory it will have some performance issue like when playing games, or 3D applications
Bu yanıt yardımcı oldu mu?
Puan 4
3 Yorum:
In my BIOS settings, there is no option to check for memory sharing or not refering anything about VGA graphics.
tarafından
same goes to me, i thought the problem is just only mine. went to the centre and they said this could not be fix...adding up the ram will only the way of it.. they also said dont be worry about reserved because it gives you same performance when you use the those graphic card...like playing games, editting.etc.
tarafından
already did upgrade the ram from 8gigs to 24 and now its reserved to 6.21 out of the whole fkin 24gigs seriously wtf
tarafından
Yorum Ekle
Just upgrade the RAM:
https://www.windowscentral.com/how-upgra...
Remember to match the pair of RAM for best results, so that means
same size, same brand and same model number.
Puan 1
Yorum Ekle
you can actually change how much of ram is hardware reserved through the bios ….however the catch is that you have to get to the “advanced” bios(not the one we get while pressing f2).the so called advanced bios can be reached by pressing a combination of keys on startup which no one knows(trust me i looked a lot)…..,another way to get to the “advanced” bios is by flahing bios from a usb which you can find the tutorial for it in youtube…i wouldnt recomend cause i personally didnt do it,nothing wrong with it(it might void your warranty tho).
Puan 1
1 Yorum:
hey could you post a video instructing how to flash bios.
tarafından
Yorum Ekle
Yanıtını ekle
[deleted] sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 17
Son 30 gün: 83
Her zaman: 17,718
