Ana içeriğe geç
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
How to fix home button
hopme button needs a little bit repair bacause it needs more power to push to activate
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Follow that link to take front screens off, turn screens over so you're looking at the back of the home button. You should see 2 very small gold prongs, these get bent flat from use (why you need to press hard now) use a flathead screwdriver to GENTLY lift them up to 45•. Replacing the button won't change a thing... You may need to change the flex under it ($1-3) easy fix
Bu yanıt yardımcı oldu mu?
Puan 4
Yorum Ekle
The home button is part of the front panel assembly.
You can get the front panel assembly apart from the rest of the iPhone by following this tutorial:
iPhone 3G Front Panel Assembly Replacement
After you have done that try playing with the connectors around the home button, and purchase a iPhone 3G home button from another site if you believe it needs replacing.
Best of luck!
Puan 0
Yorum Ekle
Yanıtını ekle
zaeem sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 20
Her zaman: 771
