Ana içeriğe geç
Released September 21, 2018. Models A1920, A2097, A2098, A2100. Available as GSM or CDMA / eSIM or nano-SIM / 64, 256, or 512 GB / Silver, Gold, or Space Gray. (Pronounced "iPhone 10 S.")
398 Soru Tümünü görüntüle
What is this thing and how do I fix it?
Hi,
This material between the front glass and stainless steel band on my iPhone XS has been damaged from a fall; a bit of it is kinda scraped off. I think JerryRigEverything called it a buffer or something in his durability video for the XS Max. I don’t know if it’s plastic, rubber or composite.
Attached image shows the material I’m talking about. It’s obviously not my phone; I don’t have a camera with me at the moment, sorry..
1) What is this material and what does it do? Is it rubber? Plastic? Composite?
2) How would I go about replacing it? Do I just get a new display? Does it come with a new display? iPhone XS Screen
Appreciate any help. Thanks :)
iPhone XS Screen Görseli
Ürün
iPhone XS Screen
$109.99
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
It’s called the bezel, It’s plastic cast around a metal frame, used to reinforce the screen and serves as structural attachment between the case and the screen. It is adhered to the glass with what looks like industrial strength adhesive and the adhesive loops the whole edge of the glass to make a water resistant seal.
Also it is the sealing interface between the screen assembly and the case. Removing the frame is extremely difficult and there seems no reliable way to reattach a new one to seal properly.
You may need to cut open the metal bezel, remove a few structural screw holes, then try to dissolve the adhesive and cut along the display, refer to below video.
https://www.youtube.com/watch?v=syC-HJLj...
Bu yanıt yardımcı oldu mu?
Puan 3
5 Yorum:
It's not a bezel, it's a strip of rubber meant to protect from impacts.
tarafından
@yootzmedia no it’s plastic cast over metal frame, it does provide some bumper space between the screen and case, now ever the core structural element is the metal frame, which holds the glass down
tarafından
@tomchai @yootzmedia @jaderichards Is it plastic, or is it rubber? Rubber would have a lower melting point, right (correct me if I'm wrong) ? Thanks :)
tarafından
Plastic. In my opinion, don't do this repair, you'll lose too much for just a cosmetic scuff.
tarafından
Its a hard plastic in my opinion but is the frame of the whole screen tacked onto the inner metal frame of the screen.
tarafından
Yorum Ekle
The piece you are talking about is the bracket that holds the lcd and glass together and holds the screen in place in the phone.
When you replace the screen these are already pre built on the screen. You could choose to replace it but that requires lots of heat and a very steady hand.
Best thing to do is to replace the screen.
Puan 1
2 Yorum:
Is this "bracket" plastic, rubber, or a composite? I'm curious. This could affect how I heat it. Am trying to be careful.
Thanks a lot :)
tarafından
It's a rubber meant to absorb energy from impacts to protect the screen.
tarafından
Yorum Ekle
Yanıtını ekle
Joseph Prekins sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 9
Son 30 gün: 19
Her zaman: 510
