Ana içeriğe geç
Repair and support for the controllers that shipped with the PS3. Released in November 2007 (Japan only) and 2008 (other countries), the six-axis lithium battery powered controller (CECHZC2) is straightforward to repair.
Controller is not recognizing inputs on pc and ps3
I have recently open my old controllers and cleaned it because i thought it will fix the no inputs issue, well it is still broken and no inputs are recognized, got to my pc and look at controller properties and started to mash buttons and nothing is lighting up even the analog sticks arent recognized, how to fix it? I cant connect it to the ps3 because the ps button is not recognized too. The model is CECHZC2H A2
Update (04/09/2020)
Here is the board, it is a different one
Update (04/09/2020)
there are 2 ribbon cables, and i think there is one burnt line
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
@supermememaker2 … sounds like either a shorted board or loose connector/ solder joint. i would follow this guide to get to the input board and look for any signs of damage. also, look for any damage to the connectors/leads while disassembling/reassembling. post back here if this doesnt help and we can try further diagnostics.
DualShock 3 Input Board Replacement
Bu yanıt yardımcı oldu mu?
Puan 0
9 Yorum:
But my controller is a different one, it has a smaller board.
tarafından
I actually have 3 controllers. 1 ok 2 bad ones. 2 bad ones are different and 1 ok is an old one and that held up good.
tarafından
ok.... what happens when you try to charge it? any lights? signs of life? what happens when you hook it up to a pc? any chime indicating recognition? any function?
tarafından
@jostewcrew when i charge it, it lights up, and pressing any buttons doesnt do anything
tarafından
on the pc it recognized it but no inputs, it only charges
tarafından
4 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Macix26 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 1,042
