Ana içeriğe geç
Dell Latitude E5400 dizüstü bilgisayar, Intel Core 2 Duo T7250 / 2.0 GHz işlemci ile çalışır ve 1280 x 800 (WXGA) maksimum çözünürlüğe sahip 14,1 inç ekrana sahiptir.
Why is windows 7 always crashing
So i have this dell latitude E5400 so its windows 7 ultimate we bought it at 2012 for me by my dad i know its old but it works perfectly si my dad bought disks for installation of windows 7 rog (custon made OS) it works perfectly then i installed minecraft at it it works fine but moving is a bit laggy tho i got a little carried away by playing the laptop itself overheated then the next day it works still fine but because of school i have to upgrade it to windows 10 because of alot of homeworks i didnt have time to use it then one year later (its 2020) i turned on my laptop and booted windows 10 then i played minecraft about 2 hours later my laptop suddenly shut down and restarted then i got a warning thing i guess it says “no bootable device detected please reseat hard drive”. Then i did what is says soo i opened the cover and put it out and put it back again after that it booted fine and another 2hrs it happened again.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @justalvin
I would suggest you to do diagnostic test.
I think this model dell has a diagnostic test inbuilt
When you power on the computer press F12… check for any diagnostic options…
or perhaps ….
Press D  + Power Button For Diagnostic
Press FN + Power On
check especially on the hard disk
if hdd is having issues, suggest you to get SSD for a long term replacement and excellent performance.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
OP needs a SATA II compatible SSD for this - the Fixed III drives don't work in this as it's a SATA II system. Should also support SATA I just in case.
tarafından
Yorum Ekle
Yanıtını ekle
Alvin Gabriel Mendizabal sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 360
