ICraig 773 CMP773-BUN doesn´t not turn on
Hi,
My ICraig touch screen tablet doesn´t turn on and keep shutting down.
Anyone may help me, please?
Thank you in advance.
Best regards,
Handy.
Bu iyi bir soru mu?
Hi,
Best regards,
Handy.
Bu iyi bir soru mu?
I have made some progress as to the tablet not turning on or loading windows . No one on the internet seems to be getting anywhere. To get a menu to show up do this. Power completely off. Then power on and immediately hit the esc key. There you will get 6 icons.. it took me weeks to figure this out . Good luck and please thank me.
Bu yanıt yardımcı oldu mu?
Hi, thank you very much for your answer. I am going try it and let you know later on f it works. Best regards!
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 769
Hi @handyhti ,
How can it shut down if it doesn't turn on?
What is actually happening if anything?
Does it do this with the charger connected and switched on?
jayeff tarafından
@jayeff Hi. I changed the USB charger in order to make sure the jack is ok. And the windows programme does not lauch properly. Moreover, it doesn´t semm to be charging.
Handy tarafından
@jayeff As you know, this tablet is equiped with a keyboard with a USB jack, in case one does not feel comfortable to use the touch screen.
Handy tarafından
@handyhti ,
OK so it was doing this before you changed the USB port?
jayeff tarafından
@jayeff I didn´t change the USB port yet. I am not using an origing ICraig battery too.
Handy tarafından
