Ana içeriğe geç
Sony Computer Entertainment tarafından üretilmiş bir oyun konsolu. PS4 olarak da bilinir. İlk olarak 20 Şubat 2013'de duyurulmuş ve 15 Kasım 2013'te satışa sunulmuştur.
HDMI PIN 18 issue
Hello everyone,
I bought PS4 with faulty HDMI port to fix it, learn something and get some practise. I am now waiting for my new HDMI port, but I have noticed something on the bord. As I checked conductivity between PADs and points from the diagram, I found, that PIN 18 is not connected to the capacitor on the right side(18).
I have also noticed that the back side of the diode and capacitor(Yellow dots) are connected and both shorted to ground.( Front side of the diode and capacitor Is connected too, but not shorted to ground.) Is that right ? I dont have another board to compare with. And if yes, where does PIN 18 go? Could that be an Encoder IC fault?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 5
3 Yorum
@marcinn ..please list which board you have for further diagnostics help
tarafından
Where can I get that? Theres SAB-001 on motherboard, Is that it?
tarafından
Yorum Ekle
8 Cevap
Filtre ölçütü:
En Yararlı Yanıt
martin … for sab-001 follow this pinout.
https://www.youtube.com/watch?v=KTQ5JkaL...
skip to the end for the testing points. if it doesnt match, theres a fault. post back for further assistance.
Bu yanıt yardımcı oldu mu?
Puan 1
10 Yorum:
Yes, the PIN doesnt match the video
tarafından
youll want to remove the component that doesnt match and test out of circuit. if it tests good, place it back and continue. something is shorted. it could very well be the hdmi contoller. i would start there and recheck the pinouts.
tarafından
Okay, I am gonna try that, thank you
tarafından
@jostewcrew so I have desoldered the diode and capacitor and noticed, that I have 3 pins on the HDMI controller (firts 3 from the left side behind the HDMI filters) shorted together. Dont you know where they should connect ? And when I removed the components, the pin Now connect to the right place
tarafından
Sorry, not only First 3, also some that Are connected to HDMI filters are shorted with first 3 pins
tarafından
5 tane daha yorum göster
Yorum Ekle
Hi, I have the same problem, maybe someone could give us feedback about value of this cap and diode from working MB. For me its 1,5 Ohms from the left side of thie components.
Thank you!
Puan 0
Yorum Ekle
14 pin point root i want
Puan 0
Yorum Ekle
i need help!!!!!!!!!
Puan 0
Yorum Ekle
i need help!!!!!!!! andrew!!!!!!!
Puan 0
Yorum Ekle
how to get sab-001 ps4 hdmi disgram motherboard!!!!!!!!
Puan 0
Yorum Ekle
Capacitor and the diode are both grounded (caps negative if polarized diodes non-striped side)
Capacitor is noise filter
Diode is a protection for polarity
Both are for local part of circuit
Puan 0
Yorum Ekle
Hey friend, do you happen to know which ceramic capacitor is the one next to the zener diode?
Puan 0
Yorum Ekle
Yanıtını ekle
Martin Jančík sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 33
Son 30 gün: 131
Her zaman: 13,123
