Ana içeriğe geç
This iteration of Amazon's Kindle Paperwhite series was released on June 30, 2015. The Kindle Paperwhite 3rd Generation is a 6-inch, 300 PPI reading display tablet that is Wi-Fi capable. The designated model number is DP75SDI.
Kindle Replacing USB socket by bypass inside
Hi,
I started replacing the USB socket in my Kindle but accidentally the conductor strips were thorn.
Now, I want to do a bypass and solder it directly to the right spot using thin wires.
The problem is that I can't determine where to solder them.
Could you advice me where to solder all 4 pins?
Thank you,
Erez
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
You see the light coloured lines that lead to where the pads were. Scrape them until you see the copper trace then solder from there.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Old post lol. Clean the board and follow the traces. Might help someone else with a similar issue.
Puan 1
Yorum Ekle
Yanıtını ekle
Erez Lahav sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 160
