Ana içeriğe geç
Kasım 2016'da piyasaya sürülen PS4 Pro, 4K oyun ve video akışı için yükseltilmiş donanıma sahiptir. Modeli: CUH-7015B.
Ps4 Cannot reinstall system sowtfware
Hi, My ps4 is broken and need some help with it.
So my ps4 is currently in safe mode with only one option which is Initialise PS4, option 7. So I download the install file. which is the reinstallation for version 7.02.put it on a hard drive and it accepts it. but halfway through installing it, it stops and says cannot reinitialise ps4 with an error code underneath it ( CE-34697-9 ). And then there’s only one option which is shut down
I have tried everything I can. Looked at every video but nothing is helping me and it’s just not working
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Is it less than a year old? Get the console repaired by sony.
If not, replace the HD with a new replacement 1TB or larger one. Then re-install / re-initialise the PS4 system software and it will work again.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
En Yararlı Yanıt
Remember the error code before asking. Guessing takes you nowhere.
Puan 2
3 Yorum:
Sorry just got it. Error Code (CE-34697-9)
tarafından
No text for this particular one, send it in.
tarafından
You probably meant "SU-34697-9", hard drive kaput.
tarafından
Yorum Ekle
Take out the hard drive and blow it out and blow out the ps4 and put the hard drive back in… should take care of the problem
Puan 2
2 Yorum:
This is exactly what I did and it worked, thank you. I was going to throw in another 1tb I had but this did the trick. Thanks to this advice I got a free ps4 Slim
tarafından
This is true 👍🏾
tarafından
Yorum Ekle
Yanıtını ekle
Riley Heka sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 50
Her zaman: 18,949
