Replacement screws stand/leg (iMac Pro 2017)
Hey there,
does somebody knows, the screws that fit the iMac Pro stand/leg mount?
Thank you for your help. :)
Kind regards
Peter
Bu iyi bir soru mu?
Hey there,
Kind regards
Peter
Bu iyi bir soru mu?
Hi @oldturkey03 and thank you for your answer. Actually it is Apple part number 923-02215 and they are out of stock from almost anywhere I checked. I’ve already checked with M2.5 and M3 but no luck. M2.5 was too small and M3 too big. They must be something like 2.7 or 2.8mm. Also the length is a problem because the standard 4mm and 6mm are not compatible also. I’ve read somewhere that the length is 5.4mm. So the only option is to buy from Apple but how is this going to work since there is no Apple store in Greece and no-one in official Apple forums responds.
Bu yanıt yardımcı oldu mu?
@sonah_t do you want me to ship you a set? Or I could try and get a screw and measure it. Are you okay with getting a couple screws somewhere near you once we have the exact size?
@oldturkey03 I've just made an order from www.applecomponents.com. Finally I found a place that has some in stock. I hope the site is legit. If it turns out it isn't or something goes wrong I will get back to you for some help. I can't be more thankful for your offer to assist.
@sonah_t I hope it'll work out for you. Yes, if you have any issues just email me. My address is on my about page. Just click on my avatar to get there. Best of luck to you and stay safe!
@oldturkey03 Thank you again. You too.
Hey there! I had the same problem with my iMac Pro stand/leg and I struggled to find the right screws. But, I eventually found a great source for specialty screws for electronics and appliances. It's become my go-to platform for all my fastener needs for any projects. They have a wide selection of screws, including those that fit the iMac Pro stand/leg mount. I highly recommend checking it out if you're still on the hunt for the right screws. Hope this helps!
Hope I helped you enough.
Here’s one source that often has them Screw Set - Leg (x9) P/N 923-02215 contact them as sometimes the site listing is a bit behind.
They are Torx T10 screws. Search A1862 Stand Screws and you can dig through to see who is selling them. The only source I’ve seen as of today is selling them for $9/piece.
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 24
Her zaman: 909
