Ana içeriğe geç
A USB (Universal Serial Bus) cable is a common type of cable used to connect devices such as computers, smartphones, printers, cameras, and other electronics. It is designed to transfer data and power between devices, and is often used for charging devices as well.
15 Soru Tümünü görüntüle
USB port/panel shorting from improper connection
Hello, I recently plugged a USB device into my laptop and I think that it shorted the USB panel on the motherboard. I think that the USB cable had been fine in the computer, but wired wrong into the device. When I plugged in the device, heard some sort of pop in the computer, and now whenever I plug anything into the port nothing happens and I am not able to find the device in the Device Manager. Is there any way to fix this that does not include a DIY or taking it to a professional? If I do have to take it to a professional are there any recommended ones?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
A popping sound implies you burnt something inside. At this point you’ll need to open the system up to locate the damaged component. If that’s beyond your skills then its time to find someone who does.
There is no software solution for this.
You may want to check the device you tried plugging in maybe using the wrong power brick. I’ve seen this a few times which a 18 volt brik is used on a device that was designed to only work with 5/6 volts.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
One other item. It’s possible you have more than one USB connector and that only this particular “bank” of USB connectors are damaged/destroyed. If you have others that work, you can consider putting a USB Hub to expand your ports if needed as a stop gap measure to repairing your board.
Dan, however, is very right that a pop clearly states a blow fuse/cap/IC component. If you aren’t good with a soldering iron or heat gun, this is outside your scope of DIY repair.
Puan 0
Yorum Ekle
Yanıtını ekle
Josh Kreinbrink sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 5
Son 30 gün: 27
Her zaman: 1,141
