Ana içeriğe geç
İlk Legacy, 1 Şubat 1989 tarihinde Japonya'daki bayilerde satışa sunulmuş, dünya genelindeki dağıtımı ise 1990 yılında başlamıştır.
electric aerial not working
hi my electric aerial has stopped workin since took battery off to re charge...any ideas...which fuse relates to aerial? 91 legacy
Bu iyi bir soru mu?
Puan -1
1 Yorum
i know this isn't aerial related but we had a similar issue with a sunroof and the battery issue. the solution was to disconnect the battery again and then it worked..seemed the cars computer had reset itself. might be a similar problem here?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
It does not appear as if your Subaru has a designated fuse for just the antenna. I would check on the radio fuse or look for an inline fuse. I attached part of the wiring diagram as an image. The complete wiring diagram from the service manual is available right here for you to download. Hope this helps, good luck.
Resim
Resim
Resim
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Yanıtını ekle
rodders sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 1,477
